Very strange base timing
hollandeclipse
39
Nov 20, 2003
Europe
Today I wanted to set my base timing correctly. And after I hooked up the timing light and also grounded the plug behind the battery I went searching for the triggerpoint at the crank. I had the triggerpoint marked with paint alreayd so it was more easy to find.
Then the follwing happens:
I found the triggerpoint/mark however the triggerpoint was not standing still but is continously moving in a anticlockwise direction, so e.g first at 10 btdc then 15 btdc then 20 btdc and so on still it has gone the full 360 degrees and it goes on and on. Very strange I have never seen this on any car. I checked my timing light on an evo 4 and this triggerpoint was nice and steady. I also tried an higher idle (1500 rpm) but till the triggerpoint was moving.
Is there anyone who knows what is going on? Car is running good and the Timing on the datalogger is steady. I tried the timinglight with the logger connected and also disconnected but no difference.
THX guys for your quick reply.
But what do you mean with a separated crankpully? And how can I check this?
The center hub and outer pulley are coupled by rubber that dries out and comes detached. Once that happens the inner and outer loose registration and over time the outer can start to wobble and fall off.
Visual inspection of the ring may show cracking or you can make a chalk mark across the pulley and if it moved you need a new harmonic dampener.
