Vent Bezel gauge install
Whammydill
78
Aug 1, 2005
Mansfield, Ohio
Ok, I have ordered a vent bezel for my Laser, I'm curious as to where is the best place to run through the firewall to install the tubing to the vent and thus my gauges. I'm going to be mounting my boost gauge on the left, not sure what I want to put on the right. Open to suggestions as to whats good to pair with it. I'm also open to debate if I should put it on A pillar? Any thoughts, experiences, and comments would be most welcome. Thanks in advance. The picture is obviously a picture of what I'm going for.
There was already a good hole in my firewall from a stereo cable installation so I just used that. For the other boost gauges I've installed, I put a small hole in the steering column boot and it works fine.
As for your other gauge, I'd go with a water temp, oil pressure, or EGT gauge.
