Valve cover problem
beansblacktsi
285
53
Apr 2, 2007
Lincoln, Nebraska
I have a 92 laser awd, About 3 months ago I replace the valve cover gasket and about a month later I noticed oil was everywhere on the passenger front side of the engiine capartment, so I was pretty sure it was the valve cover gasket right at the halfmoon. So since it was a new gasket I just cleanded it up and used a little bit of vht on both sides. It has held up for about a month but I was doing some axis spins on snow in a legal area and saw my oil pressure drop to about a quarter. This whole time I was probally around 5000 rpms. I pop the hood and see oil everywhere in the same area but more. So is there a way to fix this from happening? Is there to much pressusere built up? Just looking for some answers.
Thanks
Do you have the stock ventilation and pcv system hooked up? Sounds to me like your getting too much pressure in the vc causing the gasket to leak.
I'm not to sure if I have the stock ventilation. Here is a pic from the other day( its to dark know but might have a better pic tomorrow)
On the drivers side front of the valve cover it was overtightened but fixed. But know the others aren't over torqued.
Thanks
  • Wanted 6 bolt NT water pipe
    • chrisman287
