valve cover problem
jav401
Aug 5, 2016
Landers, California
Hello again, went to do a simple valve gasket change on my 97 gst spyderand found that a previous owner used gasket sealant ,silver ?can't get the cover off and I'm trying not to damage it. Any suggestions? Thanks
if that doesn't work use a razor blade.
Or a block of wood and a regular hammer, Tap on corners!
I've tried this with noluck I'm going to try to cut the gasket. Surgery time
Thanks for everyones help I got it off. I had to do some cutting and tapping and she finally came lose. Thanks for all the help!
  • Wanted 6 bolt NT water pipe
    • chrisman287
