Valve Cover ports
Alex, you're a Proven Member who is active with a 2+ post-per-day average....you have no reason to start new threads in the Newbie forum at this point.
Please use the appropriate tech forums for your tech questions from now on- any random tech thread that myself or the other mods find which you start in the Newbie forum is just going to get deleted. I believe this has been brought to your attention before, so consider this a second warning.
I have put two -10 an fittings on my valve cover and retained the baffle. However, you would need to offset the fittings up above the top plane of the valve cover, cut away some of the top material, and add a cover for your new port.
picture for example.
