2G valve cover oil leake
JERRICK
Mar 27, 2015
Perris, California
my valve cover is leakeing oil on to my head and intake manifold. I took the valve cover off and replaced the gasket come to finde out i have missing screws and broken ones with striped threads. So what do i do in this situation?
Tap and re drill. Also, usually when I replace any gasket, I also use gasket sealer as well. If I remember correctly, you can buy new hardware from Extreme PSI.
i did use gasket sealer but i will defiantly need new hardware
