Vacuum reserve canister
Don't need one. As when you are deaccelerating, your vacuum goes higher anyways, and that is when you are breaking. If you are having troubles breaking, I doubt it's from the lack of vacuum and caused by other issues.
No those cams really do cause very bad vacuum. Everyone that has had those cams has the same issue as you are having. I got tired of the DD with those cams so swapped to fp2's. Those cams are made for cars that are used for the track.
I also considered the vacuum canister but I just opted for a better cam in general so swapped them out. You could try the vacuum canister but the street manner of those cams are bad.
Ya they are really a bad cam for someone looking to drive the car on the street. They perform high in the rpm range but the low end is totally gone.
Bummer. . . sorry for the weak advice :(. Any who, knowing how bad they are now, I would look into a better "street" cam setup then.
Yes I agree with TSI, I would consider swapping the cams out if your looking for a streetable car. They are just a poorly designed cam street wise.
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
