Vacuum diagram for a 1g in a 2g
badassgsx
64
Feb 12, 2012
gustine, California
Hi guys I have a 1g in a 2g
1g intake and 1g throttle body
My question to you guys is what vacuum diagram should I run? I do have to smog this car
Do I need to run it this way
If you are still running with your EGR, the following will be necessary for proper EGR
It's simple, cap off the E line as well as the angled line (marked A1 or something). Then with a T, split the P line to go to where P and E used to go.
In effect drive the E line, (EGR) with the source from P.
you mean your swapping a 6 bolt into your 2nd gen? what year is the 2nd gen just curious, and cant you look at both diagrams and go from there? id have to look at the link again to see if its possible
You follow the 2G diagrams. The one area you're going to have anything different is going to be at the 1G throttle body which should have an excess of ports on it compared to your 2G, if I recall correctly.
This is what is confusing me
The problem is that the 1G EGR and the 2G EGR are sourced differently inside the throttle body. The 2G EGR has vacuum at idle but the 1G does not. So do I need to run it this way
My car is a 1996 gsx thanks guys
You need to figure out which ports on your throttle body are before and after the throttle plate. My diagrams look like they show the '93-‘94 throttle bodies having no ports after the throttle plate, in which case it would not work for 2G emissions and you'd have to figure something else out. The 1991-1992 turbo TBs have a different part number from the 1993-1994 turbo TBs and this may be what it is about.
On a '91-'92 throttle body, one port -- the P port -- should be after the throttle plate. If this is true for your TB, you need to run a length of hose from the port that is after the throttle plate and install a T. One open end of the T will need a length of hose that would go where the E port would have gone originally for your 2G. The other will go where the P port would have gone originally for your 2G. Refer to the diagrams below. As for the A1, A2, and E ports, you should be able to use any of them for the original 2G's A line since they are all before the throttle plate. Whatever you choose there is fine; cap/plug the other two.
Just cap all the lines. All you really need is fpr, bov, boost gauge. you should by now know how to smog test it. With a good tune, you can pass it with flying colors
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
