vaccum lines on a 1g
szewczyd
792
Aug 31, 2003
Oconomowoc, Wisconsin
I have got all my vaccum lines screwed up I think. Please help any 1gers
1. the line off the turbo goes to what?
2. the line off the wastegate goes where?
3. If I ad in my MBC and I tee into the BOV the other out side of the mbc goes to what?
4. Where do the two lines off the bcs go, and if I remover the bcs what do I do with the lines that were runnnign to them.
5. where does the line off the lower intercooler pipe go to?
I am going crazy :mad: :( :mad: :(
Sound like you are trying to install a mbc? Take out the bcs and then cap off the lower ic pipe vacume line. the other line from the mbc goes to the wastegate actuator. That shoud be it.
The line from the lower intercooler goes to the input of the MBC.
The line from the MBC output goes to the wastegate actuator.
The port on the air can gets capped/sealed.
That's all there is to it. I don't like using the BOV as the source for the MBC.
Steve
szewczyd said:
If I am not uising the BCS can I unplug it and remove it
Yes, on a 1G you can take the BCS out without the ECU throwing and CEL's. 2G's need it electrically attached or a load resistor connected in it's place to avoid an error code.
You might want to save the BCS and it's hoses for future use if you demod the car.
One of the hoses (I think it's the one from the compressor outlet) has a restrictor pellet inside that you will need if you put the BCS back on and have it work.
Steve
