Vaccum Line on the Fuel pressure regulator...
Status
Not open for further replies.
td06hkiko
120
Oct 23, 2003
San Diego, California
Can someone tell me what the vaccum line is used for on the Fuel pressure regulator? I am going to upgrade to an aeromotive 13109. I keep hearing people say to set the psi at 43 without the vaccum hose. So what happens when I put the vaccum hose back on???
The vac line is used to close the orfice in the FP Reg. when boosting. While your boost goes up, so does the fuel pressure so you wouldn't run lean. They are supposed to raise on a 1:1 basis as for every 1psi of boost it raises the fuel pressure 1 psi. They tell you to set it while its off because when vacuum is present in your engine, it lowers the fuel pressure a little bit but when the vacuum is gone then its fine. So set it without the hose on. Hope this helps you
The AFPR is a 1:1 regulator, meaning for each pound of boost the fuel pressure will increase 1 pound. That is if the hose is hooked back up. That hose is a boost source. Without it hooked up the fuel will stay at 43psi and not increase, putting the car in very lean condition.
-Brian
Hey thanks man!!! I'll do that. Just waiting for my install kit from prostreet. One more question. I know it may sound stupid but. My car should be at idle while I set the Fuel pressure regulator right???
Status
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
