GstRacer
- 409
- 3
- May 6, 2003
BooneDocks,
Connecticut
can some one tell me what your vac. pressure is at in bar at idle
Originally posted by Violater101
This can also depend on whether you have your balance shafts removed and or have cams. Before I had cams and was pretty much stock, I was around 18psi vacuum at idle which is about the norm (1.22 bar).
Originally posted by nine5raptor
Should be -9 psi or 18 in. Hg or -0.61 Bar 0.39 Bar abs. or thereabouts
As for the psi, I was going by my autometer gauge and I believe its in PSI or is is HG? If its displayed in HG, then okay 18. I have a Greddy guage now and don't really mess with reading it.
ok now if you remove some emissons vac line will that give you and diff reading on you boost/vac gauge my gauge 50 hg at idle so do i have a massive boost leak or is it becuse of all the emissons vac line have been removed please help
I think you're misreading your gauge. It's not technically possible on earth to have 50 in hg vacuum.
maybe my gauge is broken but i just cheacked it agian it 45 hg the gauge reads in 5 hg dash marks and it on dash mark from 50 so whats do you think broken gague
my guage read's vac in cm-hg goes all the way from 5 to 75 cm-hg the brand is spw the boost gague read's in bar's if that makes a diff?
i dont see a cm-hg converson to psi but i could just be special
You can't pump off more than 1 atm (1.01 bar) until you reach 0 and can't go any lower. On planets with atmospheres the average pressure will differ from ours. So on Saturn it would be something like 1.39 bar and on Mars something like 0.00675 bar.
