TalonJohn94
- 592
- 11
- Jan 30, 2003
Katy,
Texas
I currently have some fitment issues with my downpipe. (rubs either the oil pan or the T-case and the straight pipe flange sits about 2 centimeters away from the driveshaft) Also, I want to use the EVO3 O2 housing I got a long time ago. So I was thinking a good solution would be to buy the RRE DP "EVO3 O2" exaust because its angled for that O2 housing and starts at 2.5 inch and flares out to 3-inch downstream.
If I did this, I would be able to use the flange on my straight pipe because its some idiotic 3-bolt type. So, I would be cutting the RRE DP and the straight pipe and either doing a slip-fit type with band clamps or going a little fancier and welding the circular flanges on for a V-band setup. I think either one will solve my clearance issues.
Which is better?
Which is better?
