Using Parts fromy my 1g 7 bolt for a 1g 6 bolt...
tbird
170
Nov 10, 2002
I have a 93 tsi that has the 7 bolt bottom end.... well it went so my question is what parts can i use from it to swap over to a 91 block.... Can I use the oil pump and all that? head? thanks
dont be lazy. Search. You want to use your head for sure. The cooling passages and angles are slightly better than the 1ga head. I cant remember what all parts go together.. id just find a stacked short block with everything still on it. Make sure you do all of the gaskets tho while the motor is out...Good call on the going 6 bolt tho.
