Using o2 Dump tube for wastegate
Boostdclips99
306
Mar 19, 2006
Roanoke, Virginia
I've been running into some problems with my internal wastegate. So I bought a Tial 38mm wastegate and already have a SBR o2 dump. I was wondering if anybody has a picture of their wastegate mounted to the o2 dump. It seems to me there could be some clearance issues with the fan or oil stick. I found this picture of the setup on SBR but I don't have $365 to spend on it. I will have to remove the flapper on the internal wastegate in order to make this work so I want to make sure it will fit first. Thanks
It looks like my Punishment housing. I had to remove the a/c fan and tweak the dipstick about 1/2 inch. I'll probably setup a push fun on the a/c side of the rad at some point.
I think you'd either have to run a 9 inch slim fan to clear the WG or run a push fan. I'm going to be running a push fan because I have tons of room since I've removed the a/c.
