Using evoscan with dsmlink
tharrison365
68
Feb 25, 2013
Galveston, Indiana
I have looked for this and can not find it anywhere. So here it is. I am running dsmlink and am looking at different gauges when i came across the evoscan tablet. It allows you to view everything on one screen. I was wondering if it is possible to keep your tune with dsmlink while using the evo scan tablet to monitor things such as boost, oil pressure, a/f ratio, volts. But didnt know if it is possible to run both at the same time. Thanks
The communication protocol that ECMLink uses is different than what EVOScan uses. You can run both at the same time but you can configure the ECU using the ECMLink protocol and monitor using OBD II is you set up ECMLink to not lock the serial interface in ECMLink mode.
thanks. that helps a lot and know that i can still use my link while doing my monitoring wtih evo scan and keep my girl happy by not having gauges all over the car LOL.. she says it makes it look like it goes fast and it really doesnt even though it does go fast
