2G Used COP Setup Issue
marcman804
484
11
Mar 5, 2005
Cumberland, Virginia
I have a 2g running ecmlink. I recently bought a used coil on plug setup with the 300m coils. I believe it needs to be rewired as my car will almost start but not quite. I read that the wires may be inverted but I'm not sure which wires. I've enclosed a pic of how my current setup runs with the spark plug wires
as well as some pics of the wires and connector that is on the coil on plug setup.
Simple enough to back the two blue wires out of the connector and try swapping them to see if it starts, I'm ASSUMING that the person that wired it up has the red as the plus 12v wire, you should turn the key on and check that to be sure first before any swapping.
