2G Upper radiator pressure
Velmin hu
69
May 25, 2019
Las vegas, Nevada
Greetings, I changed all hoses with silicone hoses, radiator cap and thermostat are oem brand new. I still have pressure on upper radiator hose it’s kinda if hot. I burp the system also got all air out. Car is not over heating.
does it suppose to be like that ? Thank you
It's meant to have pressure when fully warmed up. Flex your bicep and touch it with your other hand; that's roughly how firm the hose should be.
Also, most of the time with aftermarket hoses like that, you're meant to trim the ends to match the original length of the OEM hose. I can see you have developed a kink on your upper hose right after the thermostat housing. That's not good. Drain the coolant just a little from the petcock at the bottom of the radiator until the top hose is empty, take it off and try shortening both ends of the hose so it fits nicely, is not stretched and has no kinks. Measure twice, cut once, of course.
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
