Upgrading power steering cooler?
Yeah cooler steering fluid temps and most likely increasing the longevity of the pump and other components. It really isn't necessary TBH. The people that would most likely benefit from it the most would be those that are into autocrossing.
I yanked my cooling "loop" years ago and just run a rubber hose from the hard return line straight back to the reservoir, and have never had any issues. I also auto-crossed the car like that and it worked just fine.
If you are doing heavy road racing or auto-crossing and boiling the fluid, then it's probably worth putting a decent cooler in...otherwise even the factory cooler isn't really necessary. A dirty or worn out pump is probably more likely to cause problems than over-heated fluid.
YMMV of course.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
