External Power Steering Cooler
aspekt9
344
4
Dec 25, 2005
Boston, Massachusetts
Does anybody use an external power steering cooler to replace the oil cooler loop in front of the radiator? Which brand? Where did you buy it? How did you mount it? Mine is leaking like hell and I'm debating getting an external one so I don't run into issues when I install my FMIC.
what i did when i put my front mount on, there was no room for the cooler any more, so i cut it off right at the end so it looks like a u shaped piece of tubing and just stuffed it back in to the lines, they wont come off or anything its not a high pressure line right there.
Perma-Cool 1001 - Perma-Cool Compact Fluid Coolers - summitracing.com
We installed this on my brothers 95 GST when he got a fmic. It's a pretty nice kit and cheap too. No hard data to back it up but we haven't had any issues with it. It was mounted on the drivers side of the bumper in the opening using 2 strips of aluminum (I think they came with the kit).
^^Yep, same here. -I didn't like the idea of just bypassing the OEM cooling 'loop' altogether. I found some OEM power steering cooler off of a 90's Chrysler minivan on ebay for $12 bux. -It's made by Long and has the same sized line fittings. I made a home for it in the driver's side air dam. It has worked for years now, without any issues. -It looks very similar to your Perma-Cool unit, Sax... It's OEM-style mounting bracket (with a little coercion :D) worked out great for my 1G mounting solution.
Wow thats great, thank you guys for the pictures too, they were a big help. I like the Perma kit and I think that's what I'm going to go with.
Did you guys have to remove your bumpers to mount it? Was the hose it came with enough to route?
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
