upgrading big 16g
dan2288
577
Sep 9, 2006
Shillington, Pennsylvania
I was thinking about making my big 16g in to a sleeper 16g with a 20g wheel in the td05 cover. Would there be any power increase if I put the larger tdo6 comp cover on in? The comp covers go for like $100 on ebay, just wondering if it would make a difference.
the tdo6 compressor cover will definitely be able to match the flow of the 20g compressor wheel. As far as a hp #, not sure? It will definitely be more efficient in there, which is worth something. It definitely doesn't look quite as sleeper as the tdo5 cover, but in this situation, you have to give up something to get something with either cover you choose. You would also need to get your tdo5 machined or purchase one already done which will cost about the same as getting the tdo6 cover
yea, when I decide to do it ill just get the td06 cover then
