unothodox small pulley belt sizes?
Why do you want to install one?
Have you looked around and seen the fail threads from it?
Hahaha. Its not a pulley. Its a harmonic balancer. And that pulley is garbage for your rotating assy do some research before blowing money on parts.
I personally would bot run that. If u want to change it out for anything other than stock, i would use ATI or Fluidampre. I personally just put on the ATI onto my setup
So why are you asking about belts if you sold it?
At Advance Auto, the alternator belt part number is 5040385 for the Carquest brand, and 385K4 for the cheaper Driveworks brand. If I recall correctly, the "385" corresponds with the length of the belt in mm. So, if you have an underdrive pulley, get a belt will be ending with a 375 or 365.
I had an unorthodox underdrive pulley on my 1.8 years ago. When I went to get replacement belts, I told the guy behind the counter that I needed shorter belts and he explained it the way I described.
That was years ago, so I could be wrong :)
