unable to find 5th gear
ccrunner53563
Apr 27, 2009
Milton, Wisconsin
hey i just put a new tranny in my 92 fwd turbo laser all the gears go in real smooth except fith. when i push the stick to the right the try to go forward it wont let me. could this be a linkage issue or something. i also replaced the clutch. Thanks for any help
Take the shifter cables off the transmission and see if you can shift it manually. if you still cant then it is and issue with the transmission if you can then its a problem with the shifter or cables.
:thumb: Do this
It's most likely an adjustment issue unless you bought a bad tranny
