Unable to name/find a proper flywheel replacement
Jairbear26
37
Jun 10, 2012
El Paso, Alabama
My tranny locked up so I am replacing it.
Replacing Clutch and flywheel at same time since clutch is slipping from a leak on old transmission. Putting on Exedy stage 1 racing clutch. (exedy website says an OEM flywheel is sufficient for this non turbo clutch)
Flywheel needs replaced and apparently OEM flywheels that are clearly for the car don't exist.
Need a little bit of direction here.
Everywhere I've looked online that carries the Fidanza 7bolt N/T flywheel are out of stock with no estimate on ship times.
I've tried google searching OEM replacements, and Clutch masters keeps coming up, but There is something really fishy there. With the compatibility CM's says OEM replacement FOR ALL SUBMODELS ALL ENGINES. This doesn't seem correct becuase the turbo talons have bigger flywheels and clutches right?
So mine being a Non turbo clutch and Transmission this wouldn't fit up right? Correct?!
I'm at a loss she's my daily driver and bumming rides/walking to class and work is getting tiresome.
Any information regarding an OEM replacement flywheel for a 1994 Eagle Talon ES 7bolt NON TURBO!!!! would be appriciated!
*Note the stock flywheel that's on it right now is beyond resurfacing*
I've used this EXTREME PSI : Your #1 Source for In Stock Performance Parts and it did it's job. I really didn't care for it coming from an act2100, but that flywheel is fine. Thats just my opinion.
But get the OEM tob on there as well.
Since you are n/t, I'd say call Hung @ extremepsi.com and talk directly to him, or STM. I do 99% of my business with him and he will help you out. Great guy, great store, great prices great shipping times and great customer support. Plus they price match For the rest of your post, I can't give you any helpful advice
Flywheel is just the last piece of the puzzle I need to get back up and moving again ><. I'll give them a call on Monday and see if they can direct me at all! Thanks for your input though!
  • Wanted 6 bolt NT water pipe
    • chrisman287
