turn signal relay?
Fear
47
3
Aug 28, 2010
Sweden, Europe
i have an eclipse gst -96 which i bought a bit disassembled. anyway the turn signal wasn´t working. they had cut some wires to the turn signal lever and also some cables that goes to the hazard button? or the warning triangle or what it´s called? (bad english) so i soldered them together as they were original and still the turn signal wastn´t working. behind the fan/heat control on the right side it seems to be a rather big fastener for a relay or module? and two white connectors hanging loose, on one of the connectors there is a couple of wires that have the same colour as i found on the hazard button and turn lever so i guess there is suppose to be some sort of relay there for the turn signal? on my talon awd -96 there wasn´t the same big fastener as the eclipse, the talon had a 3pin relay for the turn signals that was found in the same place.
can anyone confirm that the big fastener is for a turn signal relay with dual connectors in it? i would also be greatful if there is any pictures of one and part no.
also the electric door windows are out of order, hopefully the same relay has to do with it but i haven´t looked into it yet. it´s hard to open those big doors in the drive through;)
best regards johan
i´m swedish so my english isn´t the best:)
here are some pictures of the fastener/bracket i´m referring to.
wheres the pulg??? i have a 95 parts car... i could try to find those plugs and where they go and maybe that will help you... so do you have a picture of the plugs that arent pluged into anything?
