Turboxs leaking
mkspriggs
164
May 21, 2004
clovis, New Mexico
Hey guys just got done doing a boost leak test and found a few problems my major one though is my type-H is leaking through the holes. Is there anything i can do about this or is this a venting problem? Thanks guys
have you taken it fully apart and made sure nothing got in there? i have had 2 H34 Trbo XS valves and had no problems with either..
take it apart and make sure the piston seats properly,, as a precausion i took a smal amount of white lituim grease and lubed the insides and where it seats... and you should be using 5-8 washers i believe.. it says right in the instructions and on thier site i believe...
:sneaky:
Well i cleaned like you said it did have some crap in it and i lubbed it with some hi temp grease. I havent had time to do another leak test but i did notice a pretty good change in the car,so hopefully it got it or atleast helped until i can get a new one.Ill keep you posted.Thanks guys
:thumb:
Just make sure that the grease you used does not get nasty,, dried up and crap.... should work like a charm...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
