TurboXS Dual Stage Boost Controller QUESTION!!!
RGdsmNewb
223
Feb 19, 2006
Edmonton,
Hey i just aquired one of these from my friend for free but it doesnt have any of the wiring or toggle switch. I hooked up all the hoses correctly and have it mounted, but i'm just wondering if without the wiring it will still work correctly and which knob i put the hext key in? the top one or the bottom one? THanks
Yes it will still work, adjust the bottom screw according to how much psi you want to run. It will work you just wont have a high setting yet.
When you look at the boost controller, You need to adjust the one without the black solonoid box in it. It is the lower part. When I adjusted mine all the way down I ran 13psi
alright awesome thank you. So i should turn it all the way down first then see what it's at and then adjust accordingly???
Another thing i installed my auotmeter boost gauge and am left with a green wire with a metal clamp on it and another green wire with a blue plastic connector. Are these for lighting it up and if so where do i wire them ???
Adjust it all the wau down then two turns up .
As for the boost gauge, I just found a metal part to ground it on and for the power source, i used the wire for the light that goes around the cigerette lighter or you could go through the cd player illumination wire but the light on the boost gauge will stay on all the time or if you have a turbo timer then you can go through the turbo timer power wire
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
