Turbo water feed line source?
Ludachris
Founder & Zookeeper
8,878
4,725
Nov 12, 2001
Newcastle, California
I'll be putting a BB turbo on that requires water cooling in the next few days. The problem is I swapped out my old turbo water pipe for a non-turbo water pipe that doesn't have the provision for the coolant line. Is there another good source for water to the turbo or should I look into getting another turbo water pipe?
When I had my old 3065 I just used the old throttle body lines. Not really the lines, but I fed it from the back of the water pipe by the heater core line. And return it at thermostat housing on the back side.
For the turbo I just modified the stock 14b banjo bolt lines.
This is the same way I'm going to feed the new GT4202RV
I agree. Weld a -6an fitting on to the nt pipe. Or better yet a female pipe thread fitting so that when you change turbos to a oil cooled only one you can plug it and vise-versa. Also get rid of that nipple on the T-stat housing and do the same thing. The braided lines give a lot cleaner engine bay look aswell.
Chris, that fitting you're refering to is the return, not the feed so if you're going to use your TB coolant fittings as return, make sure you use the one connected to the pipe, not off the thermostate housing.
