turbo timer question
qban4life
41
Oct 31, 2003
hi , can any of you guys tell me how long do i need to let the car on before turning it off since i dont have a turbo timer yet .
from 1000Q's website
"A turbo timer is an electronic device which permits the car to run for a fixed length of time after the ignition has been shut off. It's sort of the reverse of a remote car starter, which runs the car before the ignition is switched on. Turbo timers usually have user-selectable run times and can usually be installed around car alarm systems.
The purpose of the timer is to allow the turbocharger additional cool-down time before the engine is shut down. The idea behind this came from the discovery that turbocharger systems can get hot enough to 'cook' the oil left in the turbo oil lines after the engine is shut off. The simple solution to this problem is to circulate oil for a longer period of time after the turbocharger has heated up. The turbo timer simply automates this process so the car operator is not forced to wait in his/her automobile until the desired cooling-down period has transpired.
Many DSM owners believe that turbo timers are a sound investment, or at least a prudent one, when weighed against the possibility of turbo damage due to oil lines partially or completely blocked with 'coke', or cooked oil residue. These timer proponents often point to the red-hot nature of the turbocharger after long runs at 55+ MPH as 'proof' that a turbo timer is a good idea. Other owners report they have run just as long and just as hard without a timer or any special attention provided to cool-down times, and still get turbo longevity and durability equal to those cars using a timer.
Driving patterns could also have a significant effect on the need for a timer. Folks who travel at high speeds almost directly to their destination will have higher turbocharger temperatures at shutdown than those who are required to wait at three or four stoplights or who drive through residential neighborhoods at low speeds before shutting down. Ambient temperatures and vehicle modifications are also likely to play a role.
There are several arguments against the necessity for turbo timers. There have been significant improvements in turbocharger design and oil formulation since the time turbo timers were concieved . This includes the advent of pure synthetic oils, which are more resistant to the turbo heat and free of impurities (such as waxes and varnishes) which contribute to coking problems. Turbochargers are also more precise and better lubricated than in previous designs. These facts are often cited as evidence for the case against turbo timers. The most compelling fact is that the majority of DSMers have never used a turbo timer, and yet there have been virtually no reports of anyone's DSM 'coking' up the turbo oil lines with overcooked oil.
don't boost for the last mile to your destination and wait 30 seconds to a minute.
Just finish whatever soneg you were listening to and that wil be enough
^ ^ ^ That's my answer. You're cooling the whole system much more at 25mph than any timer ever could.
I put up the sunshade, turn off all the accessories, pick up all the crap I want to take into the house, and shut off.
