turbo timer question
lmarinukjr
Sep 6, 2006
philadelphia, Pennsylvania
Im hardwiring my GReddy full auto turbo timer in my 92 eclipse. I hooked up every wire except the speed sensor wire. I know its pin 18 what color is it? and even with that wire not connected should i get power on my turbo timer?
I'm not sure what color it is, but you should be able to tell by which socket it comes out of. Yes, you should be getting power without it. Your TT will run fine without the speed sensor wire even tapped, it will just be a little more limited in its functions.
Here is the VFAQ diagram
http://www.vfaq.com/mods/ecu-harness-1G.html
Yup, I fixed it i hooked it up to the wrong wires out of the column, but i hooked everything up and it work now i have to figure out how to set it for auto.
