turbo timer help
selmerguy
1,810
23
Nov 14, 2004
Killeen, Texas
i bought a cheat turbo timer off ebay and want to hard wire it and the instructions kinda lack the instruction so please help me out.
the timer has 5 wires and i need to know where to tap them
the red wire goes to the normal (key off) +12: i don't know that one
yellow is 1g (key on) +12: i know that one
blue is ACC or 1g2 +12: i don't know that one
black is ground: easy
brown is hand break: easy
so i need to know two wires can you help?
Those wires you will find in your ignition harness. You'll need a test light to find them and have to use your key in the ignition on/ off, starter, and accessory wires. The key in different postions you'll be able to locate wire you need.
selmerguy said:
the acc is the constant 12 even if the car is off right?
NO, the acc wire will only light when the key is in the acc position.
ok i made that a lot harder than it was took me 15 mins. only one problem. the safety line that goes to the hand break does not work right. it is for 12 volts when the brake is down and 0 volts when the brake is up. the problem is my break does not put out 12 volts(barely makes the test lite shine) so when i let the brake down the car wont shut off. any ideas?
