quick Turbo Timer question
Civib2
187
Mar 29, 2004
Wayne, Pennsylvania
Im going to buy the apexi tt and i havent found a wiring harness made for our cars but i heard that the wiring harness for the 2g's are all the same weather its a GS-t or just a GS is this correct?
get the greddy harness for the gs, it will fit just fine
-rick :thumb:
Your Kidding?
I thought the greddy tt harness wouldnt work for the GS, you mean to tell me I spliced that beast in by hand for nothing???
Never did find the mysterious "white" wire for the bells and whistles, so it might be worth the 20 bucks even 3 hours and 12 beers after the fact.
I had to hard wire it. I have the apexi so the colors well be the same . Your goin to splice it in to a harness on the left side of your steering collum. so you need to remove the plastic there. should be 4 bolts. to remove it.
Red = any 12v constant = this can go to battery but i think theres a constant on the harness.
Black = ground = any ground.
White = O2 sensor wire. = (this is the same wire you use for air/fuel gauges if you have one installed just tap it off. because the apexi can use this to tell how hard you runing the car and it can auto adjust the time the car needs to set at idle. it also displays your air/fuel and o2 readings in a digital format which is pretty cool.)
Blue = ignition 1 = this well be spliced to harness
Green = ignition 2 = this well be spliced to harness
I well post the wires you need to splice into the harness when the sun comes up so I tell which ones to splice to. or you can just buy the greddy if it works. I didn't know that. LOL
ive got it wired and it works fine, save the white wire. On the greddy there is a speed sensing wire that will display rpm's and calculate how long it needs to idle to cool down. It also is supposed to give you 1/4 mile times based on that speed sensor data.
That is the wire I need to find and hook up.
I got a blitz harness and it plugged right in, but i was missing the harness to go from the tt to this harness so i had to splice there but at least the stock wires weren't touched
Where can you get the greddy harness for the GS harness I have the 2g harness Im guessing its a turbo harness and I couldn't get it to fit. I looked on that dsmparts.com and it only said 2g not GS.
The harness is the same any way you want to look at it. If you couldnt get it to fit then you need to work at it a bit, maybe you were at a bad angle with plug ect. If you buy any other harness adapter you will ge the same one you have.
Is the greddy harness for the gst the same for the wire hook up as you have listed above?
I dont mean to highjack the post here but i dont want to start a new one for someting thats a yes or no question. .... I purchased the apexi tt froma friend and all i received was what was circled in the picture,,, do i need that black box? (im sure i do but im hoping, no...) Also where can i get it?
i had the apexi in my car befor ei sold it and got a GReddy and i had the black box as weel, and RS_T did you just join KYDSM???
