turbo seals
96eclipsex
93
Sep 29, 2005
Rutledge, Tennessee
does anyone no if it breaks the turbo seals to adjust the way the turbo points???
and does it matter what way the oil inlet points and oil outlet
What!!??? WTF Please explain...............what part of the turbo do you want to point in another direction????????????
You are probably trying to adjust the way the Compressor Housing on the turbo faces. No it will not hurt your seals in the turbo, its completley fine to adjust the cover. As for the Center Section, keep the drain on the bottom because it has to gravity bleed back to the pan. So oil feed on top, oil drain on bottom.
OHHHHHHHHH, damn I need to go to bed, Im out of it, I completely misunderstood that one, hehe, thanks for clearing that up.
