Turbo Oil line connection
GalantGreg
297
Jul 14, 2008
Spring, Texas
Ok, while assembling my new motor, I came across this oil line. Now I am using a head from a non turbo, and there was a bolt at the end of the head on the left side as you're facing it. When I dismantled the original motor, I bagged and tagged everything, but didn't remember the banjo bolt I had left over. Then I had this oil line in the proximity of that bolt. I took out the block off bolt and used the banjo bolt. It fit flawlessly. Does this look right?
I can't be too careful, I just want to make sure. So correct me if I am wron. This looks like thet the beginning of the oil line. Oil flows from the head through this line to the turbo, and returns out through the oil return line back to the turbo?
Everything is right and then the oil returns through the outlet to the oil pan.
