turbo not running right
Status
Not open for further replies.
Timothyj94
166
Jun 6, 2011
Glen ellyn, Illinois
My turbo isn't running right, wondering if anyone can give me ideas?
http://www.youtube.com/watch?v=NG2P-uJRnGE&feature=youtu.be
Skip to :42 , As you can see the boost guage goes up to around 8 psi, then slowly lowers as the rpm climbs. It's shifts, climbs a bit, and then drops. This basclaly goes 2nd gear to 3rd gear then I let off the throttle (in this vid), I also hear a fluttering sound.
My stock FPR might be going bad. (I have a 95 btw) I had 45psi when I tested before turbo.
I think my wastegate is leaking around the flanges.
Does anyone have any idea what might cause whats going on in the video.
My wastegate is hooked up to my compressor housing. My BOV is connected to where my cruise controll port is on my intake, the cruise is just unpluged. I have a tee on the intake right away to split to Boost guage, and EGR. It is the tee that came with the boost guage that has a smaller port on the one side going to the guage. "
heres a vid at idle after run.
Turbo not running right - YouTube
Just lookin for ideas on what might be wrong? :ohdamn:
What turbo is that? What is your setup
Do a boost leak test and also fix any known leaks bro. If you wastage is leaking its not going to be able to build much boost. Also quit driving the car the way you are until you get things fixed.
Looks like a Ebay turbo. Could be ## problem right there. Check waste-gate, You should have a boost controller of some sort on there. Other wise ## running waste-gate pressure. And we dont know what pressure spring it is.
It has a 8psi spring, its leaking at the flange gotta get a new gasket, paper suck. I have a boost controller, its all the way turned down, its a bleeder style. Its a t3 turbo, standard 420a 8lb build.
Also I been driving the car like that a good 4 days, 200 miles. :shhh:
I run 93 octane pump gas, always shell or bp.
Engine is rebuilt, stock internals. 4000 miles. New crankshaft.
Status
