turbo manifold spacer?
WickedBlk95GSX
308
May 3, 2009
Knoxville, Tennessee
my t3/t4 is hitting the block and i heard that you can use a spacer to make it clear. if anyone knows where i can get one or point me in the right direction that would be awesome. thanks
Is it hitting the block or the water pipe?
some people beat the pipe in a bit for clearence.
yoour talking about a adapter flange to the head correct? go to any machine shop bring in your stock mani and get them to cut you a flange, have it welded onto the manifold at worste you will have to change out the studs to the head and depending how thick you need it you might have some clearence issues with the power steering pump and may have to remove it before the install
There are a few of the regular sites that sell just the head flange, you can use this as your spacer.
You will run into a few items that need to be taken care of at the same time. You'll need longer studs, which means you run the risk of breaking the ones that are in there now. You'll also need 2 exhaust manifold gaskets, which means one more place for leaks.
If all that is fine by you, go for it. However, taking a hammer to the waterpipe is a simpler solution that won't hurt your cooling system and should give you the clearance needed.
yeah dont crush it to were its closed just enough for the turbo to fit.
doing something like this is normal when you try to stuff a small block into an s-10 so the firewall lets you get some aggression out LOL
so i'm just having a machine shop make my old manifold into a spacer so everything will clear nicely. thanks for all the help guys
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
