Turbo lines go where?
Eddieboy480
Apr 15, 2005
Tempe, Arizona
Ok so this is my first turbo car and im having one small problem i just had my engine rebuilt its in, wired up except for my t2small is fulley connectd i got one line i thik its the coolant feed line its near the turbine on the right against the block mine has a short hose one it if that helps. for the life of me i cant find where it goes i searchd all the pics i find have the radiator hose in the way blocking the view =/ so does any one have a pic to where it goes thanks alot :coy:
I couldn't really get what you mean in that paragraph (use punctuation, it helps). If it's coming from the oil filter housing, it goes to the water neck (thermostat housing). Take a picture if you can.
Sorry on a labtop not use to it. I cant take a pic becuz i dont have camera. its one of the coolant lines on the turbo i think its the coolant feed line. its not coming from the oil filter housing Thanks for the quick reply.
These are pictures of my FP Big T28 right before I installed it. The coolant and oil lines are exactly the same.
Hope this helps!
Took a couple pictures tonight to show where the coolant lines run.
If you look at the two pictures above which I already posted, the first one (with the black hose) will be highlighted in red in the following images, and the second one (without a hose connected) will be highlighted in blue.
This image shows both hoses from kinda far away so that you can orient yourself (I've noted the valve cover and exhaust manifold heat shield). You can see the end of the "red" hose and the clamp. You can see where the blue hose connects as well. I'm betting that the blue line is the supply and the red is the return.
The next image is zoomed in so that you can see where the red line goes. It runs to a banjo bolt on the block.
Hope this helps!
THanks alot. Its shows what i needed to see. my block doesnt have the banjo bolt in it. thats what threw me off.
  • Wanted 6 bolt NT water pipe
    • chrisman287
