16g turbo-where do the lines go?
yungjon23
149
Oct 24, 2007
Denville, New Jersey
hey everyone, my turbo and everything is outside right now and i have purchased a new oil line for my small 16g turbo that runs from the oil filter housing to the turbo. But, i still have 2 other lines that i have no idea where they go. I know one is a water line, and im guessing the other is an oil line? I got the car with a big turbo on it so everything was much different.
Any help would be greatly appreciated.
Also, if anyone is local in the area and wants to give a hand i have no problem compensating you.
Thanks,
Jon
Pretty much self-explainatory.....the oil supply goes in the top, the oil drain flange is on the bottom, and the coolant provisions, should you choose to use them, are on the front and back of the cartridge.
You don't want to be in the same situation as this guy.
You have oil feed from the oil filter housing and oil return to the oil pan. You should have water/coolant feed from a hose by the radiator cap and then a water/coolant return.
  • Wanted 6 bolt NT water pipe
    • chrisman287
