turbo line in the right position?
uriel
Feb 25, 2007
hayward, California
hi well...this is my first post so it's kind of tricky..i hope this is the right place to post..:confused: i researched the forums but didn't find anything.. if there is i appreciate if u guys post them...
well i just wanned to know if the lines that come from the turbo (water lines i guess not sure) are on the right place...recently the mechanic worked on it and i just doesn't seem right.. also one of the vacuum lines i guess are not in the right place but once again not sure...:mad:
yeah...as you guys may think i got a long way to learn the basics of cars but i really like it and enjoy it. and this is a great website to start... well i am going to post some pictures to give you guys a better idea:thumb:.... thanks anyways and I'll appreciate any help you guys can give me... let me know if i did anything wrong about the posting
Yea you can plug off the one on the intake....try to take a better pic of the water lines by zooming out some.
I do not recognize anything in the first picture. The nipple, in the third photo, on the turbo intake pipe should connect to a "T" fitting which is connected to the waste gate actuator and the stock BCS(2nd pic). I can't verify my statement cause I'm using a manual boost controller and have that nipple plugged off.
For the moment, that open nipple will allow un-metered air in to the intake, causing the car to run richer.
yeah thank you all for your help i appreciate.... and i am going to post some better pictures for the water lines ....sorry about that...:confused:
Wrong. That is just a breather hose for the engine. Also, I would just bypass the solenoid, there. Don't actually take it out, but just disconnect those hoses and bypass it.
I wouldn't worry about everything. It really seems fine. I'm pretty damn sure that that hose laying under your intake in the third picture plugs into that nipple, though - if you wanted to hook that back up.
what do you mean by bypass it? just unplug them and connect them together? (for the solenoid) sorry but i am new to all this terms or words
thanks for the help
You need that solenoid unless you have a MBC (then you completely bypass it). This link shows you how to take off the restriction in the solenoid, you will get an increase of about 1-2 psi.
Alex's 2g Waste Gate Solenoid Restriction Removal FAQ
You should have 3 hoses that hook up into the intake, 1 is from the valve cover (breather), 1 is for the charcoal canister (emissions), and the last one is for the BCS.
You have the 2 hoses hooked up correct that go to the BCS, the bottom one goes to the wastegate nipple and the other goes into a nipple on the intake.
Here are a couple of used websites....
Turbo Modifications To My 1997 Eagle Talon TSi AWD
DEJON | Powerhouse
