Turbo leaks?
MaddMatt17
Aug 8, 2004
Lexington, Kentucky
Well I recently got done doing my headgasket on my car, and it wasn't the problem. I thought I had a blown headgasket due to oil getting into my antifreeze. I had just put a FP big T28 on my car as well before all this had happened. I am still getting oil in my antifreeze, I was wondering if there was anyway from the oil and water lines on the turbo that could be defective resulting into oil draining down into the water return line. Could the turbo possibly let oil go into the water lines?? Just curious... Thanks.
check your oil filter housing since the coolant goes around the oil to cool it. Ive seen it happen quite a few times where they will mix inside that housing.
