turbo leaks air
TalonRacer949
May 6, 2004
clifton springs, New York
I did a boost leak test and heard air coming out of the turbo. What is leaking and how to fix it? Is there gaskets from turbo to turbine housing? Any help is apresiated
Thx andrew
Not sure about a 14b but some people remove the compressor housing and lay on a thin layer of RTV then reinstall the housing and let it dry. I would also check to see if your housing has a hairline crack.
  • Wanted 6 bolt NT water pipe
    • chrisman287
