Turbo:... EVO3 16g ??
Twinturbo2800
288
Nov 7, 2004
Montgomeryville, Pennsylvania
ok my question is, how hard does it pull ?? harder then a srt-4 ? (only other turbo car ive riden in)
is this the turbo from an evo??
sry prolly a dumb question =)
yeah....it's from an EVO....the Evo 3.
and in regards to how hard it will pull, let me tell you that stock Evo 8s run 13s, and many full weight evos have run 11s on that same stock turbo, so you need to do a bit more research, there is way more to your setup than just your turbo.
Does it pull as hard as a stock srt4? well my tiny stock t25 would pull as hard/harder as the srt4 with the supporting mods I had when I ran it. A properly modded evoIII will laugh at a stock srt4, they have made up to just over 400 whp on this turbo & you can get 18 psi around 3100 rpms. But you need the proper supporting mods.
My evo3 16g pulls hard, all the way to redline. I would like to catch a stock srt 4 at a redlight so I could laugh as my 16 g pulls away from him.
right on :thumb: .
twinturbo2800, if you do the first stage mods found here and perhaps a fmic, at least 550cc injectors, and a piggyback system, you should have no problem blowing the vast majority of the srt-4s and wanna-be racers clear away. just do the right mods first. and read some of the tech articles found here
Just installed my evo III 16g, I'm lovin' it. Definitely a fast spool and a greater top end than my 14b. But, that's just stating the obvious.
good info guys thanks!
yea bout 350-400 is all i wanted for now,.. thanks ill have to work on the support mods =)
support mods would be, 550cc+ injectors, fuel pump, boost controller, what else ?
all of stage 1 and 2 of our tuning guide here. cams and race fuel well help you dyno to 350+ whp. I wouldn't be expecting anywhere close to 400 whp on pump gas
Well if you don't already have them supporting mods would be: Intake, ic pipes, bov, downpipe, catback exhaust, ported exhaust manifold & O2 sensor housing, fuel pump, fuel pressure regulator, depending on the boost/quality of gas you plan to run might want bigger then 550cc, maybe 650cc, boost controller, boost gauge, data logger & something to tune with. Probably also want to look at an upgraded clutch and upgraded intercooler, and the list goes on & on :p :laugh: ;)
  • Wanted 6 bolt NT water pipe
    • chrisman287
