Turbo engine into N/A, but staying N/A..?'s
One Equals Two
279
Aug 12, 2009
SLC, Utah
Hey guys,
Alright, so I have a quick question. I've tried searched and all I keep yielding up are "1g N/A to turbo engine swaps."
I know the head is identical on 4g63s of the 1g generation, but are there any block differences by chance? There's a 92 GS w/a 4g63 that is blown up. I have a 91' 4g63t that I was wondering if that would drop in just fine. So far the only thing I can see is different are the internals and performance wise, a 7.8:1 compression ratio vs. 9:0:1. Did I miss anything, and is it a straight forward swap?
Thanks!
I have never had a problem swapping the 4g63 into another 4g63 car. ive swapped old into new and new into old and they all have hooked up the same for me. i have never worked internally on one but externally they have all been the same for me.
Are there any block differences by chance? There's a 92 GS w/a 4g63 that is blown up. I have a 91' 4g63t that I was wondering if that would drop in just fine. So far the only thing I can see is different are the internals and performance wise, a 7.8:1 compression ratio vs. 9:0:1.
The turbo block has oil squirters and a knock sensor. Neither of those would cause you problems running NA. If you going to stay NA you really want to swap pistons, 7.8:1 CR is no fun without boost.
like steve said its the same just no knock sensor and oil squirters on the n/a but the compression is different to. other than that its the same but a non turbo 2g will not accept the 4g63 unless you use a evo8 motor and so on.
yes 90-94 is 1g 95-99 is 2g so a 4g63 will drop right into any 1g no matter if it was a 1.8 car to start with or anything.
But the 92' is a 1g right?
Anyway, that's really what I was looking for. Just bolting up issues are what was interesting me. Thank you!
...if you are referring to the car he is trying to swap into...its 1g (92 gs 2.0)
OH GOD, wth did i say LOL sorry i was a little drunk when i posted i dont know why the hell i was thinking 95 :ohdamn: :ohdamn: :ohdamn: i feel stupid.
