Turbo ECU in N/T
tbTalonES94
333
Jun 23, 2002
Cedar Rapids, Iowa
Hey i heard that the turbo ECU has better fuel curves so i was wondering if puttin the turbo ecu in would benefit any?? I also have the turbo cams so maybe that could help with the ecu. I also have the 450cc and the injector resistor box (can u tell im going turbo?) and i was wondering if i could throw those in and see a difference? I have a fuel controller so runnin rich can be corrected. I just wanted to see if the ECU would be good to throw in there because of the cams and the better fuel curve?
you could put the cams on, but I don't see the point of swapping the injectors unless you mod the car a lot more than just cams.
You wont need to upgrade injectors just because a cam swap. Now if you plan on modding more in the future then you might.
LOL yea i forgot to tell you guys the rest of my mods. I got an open K&N with 3" intake. I have a pacesetter header with 2.5" exhaust with no cat and a Ractive muffler. I got an UDP and the TSI cams already in. NGK plugs and some good wires. A lil bit of timing advanced and i think thats about it. So now would that ecu do any good or the injectors??
