Turbo bolt specs?
questhe
72
Oct 22, 2002
Mesa, Az, Arizona
Hi,
I am looking for the specs on the turbo bolts.
I found that they are finer threaded than the standard metric bolts of their size.
Any know of a good source for these bolts?
Thanks.
Actually, I was hoping that someone might know what the bolt dimensions are.
LOL i just went to napa and they gave me 4 for .80 cents a piece. I have no clue what size they were they just picked out the right ones for me.
blcknspo0ln said:
keep in mind the GRADE of the bolts. the regular hardware bolts may not be able to withstand the engine heat...
^^ Amen.. lesson learned after breaking two bolts in two sep turbos.
Also good Idea to replace the bolts/washers if they've old or been re/re many times.
FYI.. Slowboy sells the set for $22 (grade = 10.9 not 8.8 which hardware stores sell)
if i remember correctly the 02 housing to turbo bolts were 30x10 1.25 while the manifold to turbo were 70x10 1.25
I measured the turbo bolts at 3" which is 75 mm.
Also the thread is 1.25.
I am sure 70 or 80 would also work.
