Turbo Bolt size
lucid15
527
Oct 10, 2008
Portland, Oregon
Am still waiting on a bolt for the turbo to manifold to come, but i need my car running for tomorrow.Can i just go down to the hardware store and buy the one bolt that i need? if so, what size do i look for?
MOST DEFINITELY NOT. I'm not even going to tell you the size, those bolts are grade 11's and no hardware store sells those.
If you only need 1 of the 4 bolts that mount it to the exhaust manifold and ABSOLUTELY need to drive your car just mount the 3 bolts. You'll have an exhaust leak but the car will be driveable until the 4th bolt comes in.
:dsm:
Ok will there be a loss of power? actually doesnt matter, i need to break in my new 4.3 clutch anyway. I guess i'll just have to be patient.
Yes there will be a big loss of power... be patient and do it the right way. I don't know how many DSM hoods I've opened up to see SS hardware from Home Depot holding on the turbo. :rolleyes:
When you do install the bolts use anti-seize, its a grey/silver colored paste you put on the threads. It keeps the bolts from seizing in the hotside of your turbo from all the heat cycles.
:dsm:
