Turbo 2.0L headers on n/t 1.8L?
LaserX
38
Aug 26, 2007
Lowry, Missouri
Hi, i'm new here very new... I've got an plymouth laser with a 1.8L engine and i'm wanting a set of headers for it. I've searched all over the place and cant find anything for a non-turbo 1.8L engine. I was thinking that maybe the 2.0L headers would fit or maybe just order some turbo headers and make a plate with a pipe on it and bolt it up to the headers where the turbo will bolt up.. Do you think this will work? I am also having problems finding intake for my car. It has that huge maf sensor and i cant figure anything out on how to by pass it other than cut the connecter off a 2g and take the sensor too. I want cold air intake i know that..
Clayton
I agree w/ project 2g. BUT in other news. No, dont try and hokey up some turbo manifold to a na car. What you can do, is goto www.summitracing.com and order a cheap PaceSetter or Hedman header and go with that. As for your intake, you can A, goto ebay and use a coupler to connect the maf to the tube. Or you can B, get some huge horse dick sized intake and cut the connector off and extend and butt connect all the wires, taking note to get them all at the right places. Then, you can stick your maf where the sidemount should be and suck up all kinds of water and ruin your mass airflow sensor. =] good luck.
