2GB Turbo Side Skirts On 2GB N/T
GSX99Eclipse
Mar 25, 2003
Has anyone installed Stock 2GB Eclipse Turbo Sideskirts on a N/T 2GB Eclipse? I got the side skirts and took the bodykit off mine and it looks like it is either missing a piece that the stock sideskirts would snap into or do I have to drill holes on the body itself where the clips snap into. I'm sure this has been done before but I couldn't find it in the forums and thought I would ask before I went drilling holes into the body of the car.
Appreciate any help that can be given.
They will fit we have a thread on here some where about that.
You might have to drill some holes but it is not that hard.
I am guessing your car did not come with stock side skirts or the door cap?
You mean GS Side Skirts on a RS. They aren't Turbo only. Side Skirts are found on ALL GS Forms, GS, GST, and GSX. Installing on a RS is a little difficult, but if you search you can find it out. You have to drill holes for them to be mounted up.
Look in here maybe you will find something about it.
The door cap might be hard to install then, I would use some of that 2 sided tape on that for now If you are not sure what you are doing just make sure you use enough.
What I would do is just drill some holes out for the skirts inbetween the tires and fenders make about 2 holes on eack side front and back and use some screws with a washer and a nut so they don't fall off.
http://www.dsmtuners.com/forums/appearance-interior-exterior/118696-2ga-sideskirts-dif-than-2gb.html
