Tuning with SAFCII and MAFT help
bmxrider154
160
5
Oct 25, 2004
Cincinnati, Ohio
I will be tuning with the SafcII again this year but i am adding the Maft for blowthru purposes. I am running the pte 50 trim and i am looking into getting 780cc injectors. I know its hard to tune 650 and up on a Afc, but my main question is can i just use the Maft to compensate for the injectors and be ok for now? I dont have an eprom yet and will be getting dsmlink later on this year but need a decent tune until then. Any suggestions would be greatly appreciated. Thanks.
Bryan
Bryan
YES as Grits said, you can dial in the 780's with the MAFT then do your fine tuning with the SAFC, that is how I ran my car for over a yr before I bought DSMlink for my car... The tricky part will keeping timing under control when in boost. Since you'll be taking out a bunch of fuelk by fooling the ECU into seeing less air it will raise timing. This can cause some knock at WOT if its too high. Make sure you have a logger when you start tuning, it's not something you can do "by the seat of your pants" or "butt dyno"
Good luck and happy boosting.
Yes, too much ignition timing advance. It's going to be quite a headache to tune with piggy backs on 780's.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
