Tuning the Timing Advance
if the throttle shaft seals are leaking it will definately make a big difference. And your seals are probably the original 15 year old seals so they are probably part of, or all of your problem.
jonheslop said:
In the factory service manual, it says to take the ISC out and have a friend turn to ACC on and off with the key and make sure the ISC motor moves in and out. It tests fine when I do that, so does that mean the ECU is working properly? Or does that not mean anything?
It's a good sign but unless you have seen both a good ISC and a bad ISC rehome when you turn the ignition on it's hard to tell the difference between a smoothly stepping ISC and one missing steps because one of the drivers is bad.
I usually use the AC idle up and watch the ISC steps once the car comes up to temp to see if it's working.
Steve
I'm trying to think and elimate all my problems. I've narrowed it down to the ISC and some sort of gasket/seal leak. Other than that everything has been tested or solved. I hate to buy a new ISC is that's not the problem. And I hate to buy a new ECU if that's not the problem. I'm just going to wait for these shaft seals to come in so I can start small.
The linkage is fine, not too tight, and I am going to check the FIAV and rebuild the throttle body as soon as the parts come in.
