Tuning questions...
Joshuah Stedman
67
Jul 22, 2009
Canal Winchester, Ohio
ok so I just got my safc and datalogger installed and I have a pocketlogger setup for tuning purposes. I know How to tune, it's just that I don't know how many lbs of boost I have to play with before my fuel system poops out on me(stock injectors, rewired pump)?
Also how can you measure the duty cycle on palm n' stein? All I have is pulse width, can you use that in the same way?
any help would be appriciated...
What kind of turbo? and what kinda fuel pump/injectors?
now I cant get my fu##ing logs off of my palm. Im and the palm and stein screen and it says hit transfer and i do and it just goes away....
I myself never liked palm n stein and dont know anyone that uses it. I would download MMCD. Its a lot better and I trust it. Its also a lot easier to use.
I would start off at 15psi. If you dont have a WBO2 I would be careful. The stock afr is really rich and you will most likely need to pull fuel before adding even if upping the boost. But I dont like leaning out a car without a WBO2. You can easily burn up a valve.
I have mmcd, but my 02v is weird... it's says it has like a 2.5v on the sensor at idle...
and Is It any use to tune a little with the stock injectors?
get a wideband ,without a wideband you are tuning with a blindfold on
as for the injetor it all depends what do you want to do with the car ?
what turbo do you have ? check your IDC are you knocking
Tune for knock. Use that link I gave you to determine if your curve is decreasing or flat lining (knock).
there was no link, but I looked it up and my timing curve is good i think. Im around ~20 deg. of avance @ wot @ 16.5 psi.
